Status
Not open for further replies.
1 - 2 of 2 Posts
I am considering buying one of these receivers to use with 4 ohm speakers. I have heard the Pioneer has had some shutdown issues and also noticed that the Denon is specified for use with speakers of 6 ohms and higher. I am pretty new to all this and would appreciate advice as to whether or not I should be considering either of these receivers. Thanks!
Sarkis
I believe that Denon does officially support 4 ohm speakers. Pioneer does NOT officially. However, the shut-down problem that you mentioned has long been fixed. My 45TX is happily driving the 4-ohm Hales fronts at insane levels of volume (at times). :D
1 - 2 of 2 Posts
Status
