Not true. DVI will be enabled when the HDCP protocol is finalized.
Originally posted by Fergy Not true. DVI will be enabled when the HDCP protocol is finalized. |
Originally posted by Jim Boden Using a scaler, like the NRS or Digital Leeza, gives a better result than using a panel's internal scaler. DVD's on my 503 look almost as good as HD, and that's 480i being "up scaled" by my NRS to 1280 x 768. |
Originally posted by Andrzej Jim, I know that you are right. But I was asking how this is possible. A DVD or SD signal carries much less information about the picture than HD signal. Upconversion cannot create any additional detail about the picture. So why does it look better? Andrzej |
Originally posted by will792 I am almost sure that high level scalers can add information by recognizing patterns in the picture frame. If you have a two line (2x7) pattern as follows XX00000 XXXX000 you can create twice (in each axis) higher resolution version (5x14) XXXX0000000000 XXXXX000000000 XXXXXX00000000 XXXXXXXX000000 A real TV picture would not be that simple but the concept still applies. It is relatively easy to check code of dScaler since it is publicly available. Will |
