Denon 5900 into Sony HS20 via DVI cable. 1080i mode.
Something curious. Went through the AVIA crosshatch pattern and noticed that I am losing about one cell column on the right hand side. It's as if about an "inch" of the pattern from the right edge is chopped off. If not for the marks on the crosshatch, you would not notice this.
It does not seem to be the overscanning past the right border of the screen, as I have zoomed down the image and its still missing. It appears more like its sourcing from the 5900 which is curious...
When playing any DVD with a THX logo, this is manifesting itself as a right side biased THX logo. Other than that, this is a hard one to find while watching a movie since you really do not know where the right edge is without some sort of pattern like AVIA.
I have gone into the Denon Pic Adj and set the horizontal to -7 which is as far as it will push the crosshatch pattern to the left as possible but I am still losing about one cell column of the image.
This is via the 1080i mode on the DVI but can also be seen on the 720 and 420 modes as well.
Has anyone else come across this ? If so what was the solution ?
[sigh]....just when I thought everything was hunk-a-dory.
Thanks In Advance,
alby
Thanks In Advance,
alby
