1 - 3 of 3 Posts
· Registered
I noticed that all of a sudden (well, after the cleaners "cleaned" the place), my AVR remote inputs are messed now.
SAT/CBL was #2 but when I press #2, the receiver goes to TV.
When I click on #1, it goes to SAT/CBL instead of DVD.
Not sure what could have changed, but I am looking for help to get the settings back to how they should be.
Also, anything I could do to avoid this in the future?
· Registered
Discussion Starter · #2 ·
bump?
· Premium Member
Either the cleaning crew was messing around with the Quick Select buttons on the AVR or perhaps the batteries in your remote are getting weak and must be replaced. Either way, simply set up Quick Select #1 with the settings you want and re-memorize it by pressing and holding the Quick Select #1 button on the AVR front panel for a few seconds. Do the same for Quick Select #2.
1 - 3 of 3 Posts
