Status
Not open for further replies.
1 - 3 of 3 Posts
I recently purchased a Denon AVR-3300 from a friend and cannot get the
digital inputs to work. On the receiver I have set up the dvd input to
optical or coaxial depending on which im trying. Also on the dvd player I
have set up the output correctly. The three options that can be set on the
DVD player are Dolby Digital/PCM, Stream/PCM, or PCM only. The only time
any sound comes out is when the DVD player is in PCM only but it only shows up as Pro Logic DVD. I have tried different digital coaxial cables and
optical cables on two different DVD players and neither would work. Is
there anything I am missing or are the digital inputs on the receiver
broken?
FYI:
DVD Player: JVC XV-N55SL
Receiver: Denon AVR-3300
Speakers: Wharfedale 8.1 Diamonds with Wharfedale 8.1 Center
Thanks in advance for any help as this problem is really annoying me.
Have you set the input of the 3300 to Auto - it's the set of 5 buttons to the right of the power switch. I just checked mine, and if I push the PCM button, it appears to act as you've described.
Good luck,
1 - 3 of 3 Posts
Status
