1 - 2 of 2 Posts
Hi I got a Denon AVR-3802 surround sound reciever off craigslist and it works perfectly except the guy didn't have the original remote and so I got the gamer pro from radio shack 15-133 & I tried all the codes a couple worked but they wouldn't work for me to use on screen menu for system setup for setting speaker sizes and distance, so I did a code search and got the remote after turning it back on and then I was pressing the CH+ button and the source changed to tape and the light blinked x 2 and then I hit the menu button and was able to setup on screen & I decided to see if I could find another code for more advanced functions and now I wish I never would have changed it because I can't get the on screen menu to work on my monitor as I did before! I also did get some better functioning on another forum but some of the codes wouldn't work is it possible to reset the radio shack gamer pro 15-133 remote back to the way it was when I first bought it?
1 - 2 of 2 Posts
