Hey all. Im new to this forum and I am hoping that somone here can help with an issue that I have.
I am hooking up a Denon AVR-4306. I have the Zone 1 hooked up and configured to play the surround sound and that works fantastically.
According to the owners manual, you are suppose to be able to have two other zones, and with that be able to assign, say for instance a Zone 3 to use the Surround Back amplifier as a speaker level output to the other speakers for that zone.
I cannt seem to get this part to work. I have done the power amp assign to use the S.back as the zone 3 output, but I am not getting any power to those speakers. The speakers are in another part of the house and I know that they are wired (did a basic test with another amp so i know the speakers and wiring is fine).
I have done everything that the owners manual says to do and from the way that everything is hooked up, it should work.
Has anyone had a similar issue while setting up the 4306?
Any help or suggestions would be greatly appreciated.
