Hi! I'm looking for a new AV Receiver and my current search has pointed me to Denon AVR-X2000 (The other serious contender right now being Yamaha RX-V775). However, I seem to be in a sort-of unique position, that I need BOTH optical in AND HDMI in for audio (obviously not at the same time) with just one (HDMI) video signal.
I've read through the Denon manual, but I'm unable to find specifics of how the receiver works concerning this need.
Okay, so the manual says I can assign inputs pretty much however I choose, yes? BUT, can I choose one HDMI input for multiple inputs? Say I have two settings, named "Games" and "Movies". Can I do this:
Movies: HDMI-1 Video + HDMI-1 Audio
Games; HDMI-1 Video + Optical Audio
And just change between them via the quick select buttons?
AND/OR, can I do this:
Just one settings . let's say named "Computer".
I connect both HDMI and Optical connections. Then in the Audio Type menu I select "Auto" (it allows "Digital", and "HDMI" also).
Can the receiver then play sounds from BOTH optical audio AND HDMI audio, depending on what the source sends?
In all cases the output will be HDMI for video and audio via speakers. HDMI and optical audio will NOT output at the same time, as far as I know.
Why I need this? - read on if you want the full explanation.
I'm connecting my computer to the receiver (and possible few other sources, but that shouldn't matter). My Music/Movie sounds will be output through the HDMI (via nVidia GTX680) in 2.0 - 7.1, depending on source. The sound will be unaltered by the computer (as much as possible.) I will also connect my X-Fi Titanium soundcard via optical to the receiver and all my game audio will be output via that (processed by the soundcard/software as much as needed, encoded in DDL5.1 or DTS5.1). This way I will get to enjoy both "pure" movie soundtracks and processed game audio. In the latter case, it would be ideal if the receiver could upmix that 5.1 to 7.1, though that's not a deal breaker.
In the case of the Yamaha, I know (I've read the manual) that I can save some settings behind the SCENE buttons. However the manual does not specify what gets saved. So if I set SCENE-1 as HDMI video, optical audio and save that. If I then set the HDMI input to use HDMI audio, will that overwrite what was saved in the SCENE, or can I just save this new setting into SCENE-2 and quickly switch between them by hitting the respective SCENE buttons?
I *think* I'd prefer the Denon (I heard that Audyssey is better than the Yamaha alternative and that the MultiEQ in the Denon is superior to YPAO. But the Yamaha has analog pre-out, which I would like to have.) I don't know though, I've never owned either. My current receiver is a Sony STR-DB930 from -99/00...
If both receivers can do what I want, feel free to praise your receiver of choice and tell me why should I get either one.
ps. What does NOT matter to me in the slightest: WiFi, Power (watts), iPod/iPhone connectivity, Spotify (etc.), multi-room (zones) or sound quality (to a point, yes, but... most of my music is in mp3 format and I'm incapable of hearing anything beyond 14kHz.)
