1 - 3 of 3 Posts
· Registered
I have a Denon AVR-687 receiver with a DVD player and HD Cable Box hooked to it via component cables.
All was working fine until somebody fooled with it and I can't get it to work correctly again.
I went into setup mode and set Component 1 to DVD and Component 2 to TV.
After doing this, the dvd picture shows on the tv but the cable tv does not.
I can't get sound for either one to work.
Both devices are set to analog and I cannot figure out how to set them to digital.
Any help appreciated!
· Registered
On older Yamaha receivers, hitting your DVD button multiple times would cycle through analog, digital and auto.
On my newer Yamaha, there's an audio select button on the remote which cycles through similar options.
Maybe Denon works something like that?
· Registered
Manual no help?
And you're mentioning you have video component cable from your sources going to the receiver? I thought you were having audio issues?
1 - 3 of 3 Posts
