1 - 8 of 8 Posts
I got a great deal on a Denon AVS-889 receiver. I got it home, hooked it up and I can get the onscreen menu on my tv. I am using an component cable to connect the receiver to the TV.The Sony plasma tv puts out Video 4 which is correct but it shows a signal of 525/60. I figuired there would be a video out signal selection in the menu but I could not find anything. I was using a Marantz SR8001 and it worked fine, so it should work. Has anyone come across anything like this.
Mark
Discussion Starter · #3 ·
Sorry. If you change inputs, in the top right hand corner the TV shows what input you are on and the signal.
Basically
Video 4
525/60
The 525/60 is where I get confused. What is that?
Technically it is PAL....
You know there are two Standard Def standards.. Pal (Think mostly Euro here) and NTSC (Think mostly U.S. here)
Discussion Starter · #6 ·
I talked with the Denon tech guy today said that it could be the receiver. Anyone have any issues like the one I'm having?
Mark
1 - 8 of 8 Posts
