I just bought a denon dht487dv open box dirt cheap because it is missing rear speakers and the dvd player, but I got a great deal and can get good rear speakers once i get the rest working. I am have a htpc and am using dig. opt. from the pc. I have set up the input so that it should accept it but i am still getting no sound. I called denon and they said it was my computer. so then I called intel (intel dg33tl mobo) and they said, you guessed it, it is the receiver. Since the computer is actually showing that it is outputting sound and I do have a signal at the end of the dig opt cable I am inclined to believe that it is the receiver. Anybody have any ideas?
My second problem is sub hum. I have the receiver and sub 'isolated' together and on the same plug with nothing else APC battery back up. Also there is no third prong ground on either of these. All the cables are monster except the speaker wire which is cheapo had laying around from long since passed radios.
