Originally Posted by toyz4boyz /forum/post/0
I was my understanding that the Denon and Pioneer Elite firewire solutions had inherently less jitter & clock synch problems...a distinct advantage over HDMI.
This is true. Denonlink and firewire solutions are definitely better than HDMI as until HDMI 1.3, jitter will continue to be a big issue. However, assuming the DAC in the Denon disc player is of equal or better quality than your pre/pro, analog should be the best. In theory, jitter should be even less of an issue internal to the disc player than the firewire connection.
Why not necessarily the best solution? I am curious, and would appreciate your assistance.
Using a GOOD receiver or a pre/pro (with a decent analog pre section) and a GOOD disc player (either with good DACs or a transport with a good external DAC) , analog should be the best connection method (convenience issues aside). This is because you want as much separation and as little interference as possible:
1) There is no getting around the analog pre section of your receiver/pre. Your signal will have to pass through it before going to the amp.
2) There is no avoiding the digital circuitry/bass management of the denon unit. The signal will have to be preprocessed by it even to get to the digital out of the firewire. AFAIK all bassmanagement settings apply even if you use firewire.
3) If you use analog connection, most good receivers will have a DIRECT mode--on my Arcam its called Stereo Direct (even though it applies to the multi-ch inputs) but I am pretty sure the Denon has such a mode that allows you to bypass all digital circuitry and get the analog signal straight to the analog pre-amp section. On this mode, no bass-management, room-correction, dsp processing is applied, and should give you the cleanest most transparent sound.
