Measurement Tips
The first measurement must be taken in the middle of the listening area. After that, the exact location of each measurement is not critical, but be sure to follow these guidelines:
- Use only the microphone included with your AVR. If you cannot find it, contact the manufacturer for a replacement.
- Attach your microphone to a tripod.
- Take the measurements at ear height and with the mic facing the ceiling.
- Start the measurements from the primary listening location and spread out from there. - - Approximate distance from the first measurement position is 2 feet in any direction.
- Focus on the central listening area and avoid extreme positions such as the back wall or too far beyond the left and right speakers.
