Denon x3700H setup. Help!!!!!
3848 Views 28 Replies 12 Participants Last post by  dimwit70
Hello all. I am trying to figure out exactly how to wire my new system. I have tried using the bookshelve speakers in the "surround back" terminals on the AVR but not getting much volume out of them for some reason. I think I got in over my head a bit, but I have always wanted a good surround sound system so here I am. I wish there was a school I could go to for this stuff because I am completely lost. I have a tall entertainment center and have two of the bookshelf speakers sitting on top of it and two of the same in the rear. The 2 atmos speakers are in the front sitting on top of the towers. I hope I can get some good advice here, I would very much appreciate it!! My system is.
AVR-Denon x3700H
1 Klipsch RP504C Center SPKR
2 Klipsch 620F floor SPKR
4 Klipsch R51M SPKR
2 Klipsch R-41-SA Atoms SPKR
1 Klipsch R-100SW Subwoofer
1 - 20 of 29 Posts
Have you run Audyssey with the mic that came with your recevier?
AVR-Denon x3700H
4 Klipsch R51M SPKR
Surrounds don't spit out much information.
As a quick test you can turn on Dynamic EQ, which should boost the sound coming from the surrounds, but you still won't hear nearly as much information as the front 3 speakers.
AVR-Denon x3700H
4 Klipsch R51M SPKR
The easiest solution is to run XT32 Audyssey room correction. It will ask you all about your speakers and will tell you where to hook them to the receiver. You have a 7.1.2 system. The 7 is Left Front (1), Right Front(1) and Center(1). You have Left/Right Surrounds (2) and Left/Right Rear Surrounds (2). The X.1.X is your sub woofer and the X.X.2 are Atmos speakers. If you plan to install wires behind walls and ceiling, test all the components first.
You should start looking through the menu and get used to where things are located. The manual is also your friend. If you run XT32, then it will configure everything for you such that you may not need to access the menu ever again.
... I am trying to figure out exactly how to wire my new system. ... I wish there was a school I could go to for this stuff because I am completely lost. ...
Step 1 (IMO) is the owner's manual. It'll tell you how to hook up your speakers and run Audyssey. (y)
  • Like
Reactions: 1
Yes, I did run Audyssey but it did not seem to fix the problem. Maybe Surroundsound back just sucks?🤷🏻‍♂️
Again, not much information is being sent through the surrounds to begin with...
I was told to play the movie "Master & Commander" to test my sound and that was great advice!! I found out that all is working great. Like someone else said here, some movies just don't have good sound. Thank you guys. I will try the other things suggested here as well.
  • Like
Reactions: 1
Yeah you're not going to get much out of the rear with a lot of content and even more so if you're streaming vs. disc.
  • Like
Reactions: 1
Could I be underpowered with this AVR? Would getting an external amp help? And I am using 14 gage speaker wire. Is that ok? My longest run is about 30 feet soooo?? Thank you for your help...
14 gauge speaker wire for 30 feet is fine. It's not the AVR, the surround channels are not meant to stand out but rather blend in.
You have Klipsch speakers with high sensitivity. You have plenty of power to drive them to loud levels. Make sure all your speakers are set to Small since you have a subwoofer.
Would the Panasonic DP-UB150-K be an ok 4k player for my setup? Or would I be short changing myself if I pick this unit?
oh. and what would be a good HDMI cable to use for this 4k player? Thank you so much!!
Look at the Sony UBPX700/M or Panasonic DP-UB420-K. At the very least you're going to want wifi for firmware updates. Separate audio and video HDMI outputs are better if you want the most out of your HDR and don't want to deal with handshake issues through your reciever.
Any quality hdmi 2.1/2.2 certified cable will work fine. Do not let a salesman at best Try sell you a $100 hdmi cable, You can get a pair of good cables from monoprice for ~$50.
Or just use certified premium HDMI 2.0, unless there is a need to deal with sources that require HDMI 2.1 (4k/120Hz, 8k 60 Hz). More like $20 or less, for a couple of 2m or 6' cables.
3159574
See less See more
A great way to test all speakers is to turn on the Multi Channel Stereo audio mode. This should activate all speakers.
  • Like
Reactions: 1
You can also go to Netflix and search for "Test Patterns" for a bunch of tools.
If you only have one pair of surround speakers they are your side surround speakers and should be connected to the Surround posts, not the Surround Back posts. ;)
The Atmos speakers should be connected to the Height 1 posts.
3159666
See less See more
  • Like
Reactions: 1
Very good advice from all! Thank you so much. I went with the Sony UBP-X800M2 player. Should I be using the HDMI audio port 2 on it? Or is the audio/Visual port 1 enough?
1 - 20 of 29 Posts
