The “side” surrounds are the surrounds no matter if they are to the sides, slightly behind to the sides or all the way behind as long as you dont have ‘surrounds’+’rear surrounds’ also.
Everything will come from the surrounds that is supposed to be behind you. Thinking of them as “side” speakers isnt right because things that are supposed to be straight to your side wont be just in the surrounds it will also be a little in the front L or R also.
If you are used to an old analogue 5.1 system you have used surrounds all this time no matter where you had them placed(within reason).
