Hi all,
I just purchased a pair of B&W 604 tower speakers not even one month ago. I love them to death and am super protective when i have guests over with kids and their little hands...
I'm really upset right now... mostly with myself. I had been trying to repair a crack in the plastic of a cheap portable dvd player (less than $80) so i had krazy glued it and piled some encyclopedia books on it to put some pressure until the glue dried. Well the glue worked and the crack is fixed... so i went to put the books back and grabbed a stack. I was too careless I guess and the top book slid off... bounced and rolled on the ground and right into the cone of my tower speaker woofer.
ARGHHH!!! I flipped out . almost put a hole through the wall actually. Not even a month old and I $#^$%& up a perfectly mint condition set of speakers that cost me and arm and a leg to save up for.
Anyway I did some research and have tried scotch tape (not strong enough),
krazy glue on the end of a little peice of wood.. (didnt bond to the peice of wood (i only put a drop) rest seemed to disolve on the aluminum)
I also tried the vacume cleaner attatchment and no go..
I've run out of ideas...I also dont want to cause more damage than is already there... here are some pictures so you know what im talking about.
I'm thinking of writing a letter to B&W and ordering a replacement cone... do you think they have replacements or would i need to buy a whole new woofer?
a friend of mine suggested taking it to a body repair shop and using the suction device they have... what do you think?
