1 - 5 of 5 Posts
Hi,
Can any one please guide me with volume logic where in if I press mute I would like to have an feedback showing volume bar completely disable and if i unmute it, it would show the earlier volume status..
Just draw in a gauge and use it for volume status feedback. Use the inactive and active state of the Mute button to show when it is active or inactive.
Or use the mute status to trigger an analog initialize (named with the same signal name as your volume feedback signal) with a value of 0.
When you unmute push the actual room volume value again.
1 - 5 of 5 Posts
