1 - 17 of 17 Posts
HI folks. I built an addition with a full basement (18x26'). I plan to use the room for:
-bar
-pool table
-theatre
The theme I'd like is a circa 1920's "Speakeasy" ie. an underground bootleg bar. Prohibition era what you might find in Chicago or NY etc.
I'll post pics on the room layout but I'd like the room to look really old, like a factory or warehouse.Some ideas I have are:
-reclaimed brick on the walls. Or patches of brick exposed where it looks like the plaster is falling off
-factory lighting
-old factory floor
-an industrial door into the room
What could I use for flooring? Maybe cobblestone? What would look good?
I couldn't find much online re this type of rec room theming
I think you'll need every bit of that space just for the theater. Fitting all that in the space have will be tough.
Sent from my Droid MAXX via Tapatalk.
How wide is the theater? 9"?
Discussion Starter · #6 ·
Hehehe.
I was thinking of an 8' wide screen like I had in my last basement (around 2007 with a Sanyo Z2)
I like to sit 1.5x screen widths away. The couch is about 14' away from the screen so an 8 or 9' wide will work
Originally Posted by DGF  /t/1523745/design-ideas-for-my-speakeasy#post_24516635
Originally Posted by dhendriksen  /t/1523745/design-ideas-for-my-speakeasy#post_24516589
.....I think I see a problem.....
I meant 9', not 9". To clarify further - NINE FEET. =)
You'll only be able to get at most, 3 seats wide in there. 9' seems really narrow to me. Mine is ~15' 9" and doesn't feel any to wide.
Originally Posted by BIGmouthinDC  /t/1523745/design-ideas-for-my-speakeasy#post_24517531
You need a bathtub and a mannequin
I don't think he has room for it. Space feels tight without the mannequin.
Discussion Starter · #13 ·
Very cool ideas! That ceiling looks awesome, kind of coppery looking.
For the screen, which is recessed in the step footing, I'm thinking of cabaret lighting something like this. I saw it in a Vegas casino (Paris I think) with the white lights
Building on the industrial theme - how about a false wall of backlit factory windows? I also love the old-style wall-mounted power switch boxes.
Accessories could include a violin case, a hat stand with Al Capone-style fedoras hanging on it, old school wall-mounted telephone, brass bar kick rail, etc.
Discussion Starter · #17 ·
Cool, I like the factory windows idea
1 - 17 of 17 Posts
