1 - 13 of 13 Posts
I'm building my very first official HTPC. I've got most of the components down just fine. However, the one thing holding me back is a way to actually control Windows and run files etc. Currently I use Mediaplayer Classic or Elecard player to play video files, and I'm not sure if there's a perfect remote/keyboard/mouse hybrid that does the job here
Within a reasonable budget, what's a good way to control an HTPC from a sofa? Bear in mind I own a Logitech Harmony for XBOX360 remote already, though I'm not sure if I can do anything with it with regards to HTPC usage.
Any information appreciated!
Discussion Starter · #2 ·
Ah, and before I forget, anyone got any good recommendations for a region-free-able DVD drive/recorder? All the new ones don't seem to be firmware hackable.
I have a lot of R2 movies from the UK.
Ok, sounds to me like you don't have any HTPC software running. I would highly recommend Mediaportal for an HTPC frontend if you are running XP (if you aren't there are several option available). also any oem windows media center remote will work with Media portal.
Personally, I'm not a fan of HT frontend software myself. I prefer to just use the best programs for each job. For me that amounts to:
Zoomplayer => DVDs
SageTV + MyHD => HD/DVR
iTunes => Music
To do this I use a quality universal remote (URC 200) and Girder Software.
It requires a little bit of imagination to setup everything to work fluidly, but the configuration capabilities are limitless.
-Suntan
Discussion Starter · #6 ·
I have no idea about media centre frontends. I'm just using XP Media Centre, and was going to wing it from there.
I guess I need more help than I think!
You can use media center for your front end and wing it from there.
I do everything through media center some don't. To me I like the ease of not having to launch other applications.
I use the harmony 880 in the living room
and the harmony 890 in the bedroom to control xbox 360.
well Windows Media Center IS technically a HTPC front end. and you can do everything from the MCE interface (watch videos, movies, dvds, even use it as a PVR)
If you want to tackle using MCE since you already have it, you can always get the MCE USB IR receiver and remote, works out of the box with no configuration.
http://www.pcalchemy.com/product_inf...emote-controls
but if you don't really plan on using MCE gui at all streamzap makes a nice out of the box control setup, and their software has almost every single media software built into it for controlling.
also your harmony remote can be programmed to control either setup.
- Josh
Streamzap remotes will work with Windows Media Player, as well as most all windows apps without needing a frontend. As stated earlier, having a front end like Mediaportal, Meedio, Xlobby, etc, is highly preferred, easier to use, and keeps everything nice and organized.
1 - 13 of 13 Posts
