Hello all,
I am doing something stupid and I can't figure out what it is... so what better place to find the answer than right here....
I have a BarcoGraphics 1208 projector that I finally have in its final installation position. I have gone through the installation procedure for raster centering, focus and lens adjustments, etc. I now want to converge an input, my computer desktop. Since it is my only source, it should be the only thing I have to converge.
I want to run a 16:9 desktop resolution. Since the Barco needs you to converge an input with the source connected, I went about setting up resolutions using powerstrip. The problem is that the barco won't sync to any of them.
It will run up to 1024X768 just fine and syncs automatically. Anything above that simply doesn't work....even standard desktop resolutions like 1280X1024 won't sync. All I get is a wonderful message on the screen saying there is no longer an input connected. I know it isn't an issue with my resolution settings because plugging in my computer monitor immediately makes them sync up and display in all their glory.
This barco is supposed to scan to 135Khz. So what is the problem? I know I watched a badly converged 1280X720P high definition loop from a mini satellite dish before I purchased the unit.
Any ideas of why it won't sync to a computer desktop higher than 1024X768? It doesn't matter what I attempt to define the projector as in the display properties (standard Super VGA up to 1600X1200... nothing works).... please advise. I would really appreciate it!!
