thanksESPN Radio is carrying the game nationally, in Detroit that's 104.5. It's also available on their live stream.
I think I noted in the post that they are NOT broadcasting in 4k at this time. The point that I tried to make is that they separated the ATSC 3.0 and ATSC 1.0 from the channel selection. NOW, it is able to watch or schedule a recording using which ever tuner you want.I think you're conflating "4k" with ATSC 3.0. There were no NFL games produced in 4k, today. There is no FOX regular programming produced nor distributed to stations in 4k nor are there any plans to do so.
That's not how I read this:I think I noted in the post that they are NOT broadcasting in 4k at this time.
I watched a couple of the NFL games tonight that were broadcast in "4k"
Correct terminology is important on a technical forum such as this. Otherwise, members are led to believe things that are not factual and that misinformation spreads. I would not be surprised to start seeing posts in other areas claiming "Detroit viewers are getting 4K Sunday NFL games!!!" We've already had to tamp that sort of misinformation down a number of times.The point that I tried to make is that they separated the ATSC 3.0 and ATSC 1.0 from the channel selection. NOW, it is able to watch or schedule a recording using which ever tuner you want.
You are the broadcasting expert and authority on media distribution, I don't question that.That's not how I read this:
Even the article @LNEWoLF linked is telling in that they use the term "4K quality" which reminds me of the HD Radio selling point, "CD Quality." It ain't 4K and probably won't ever be. You might get some HDR (I think WMYD has hinted at that), but with all they plan to use WMYD for, anything beyond 1080i/p isn't going to be a priority. That could change if Sony, LG, et al decide to back the Brinks truck up to Broadcast House.
If you also read this part that I wrote, I said >> "Now they have taken the 4K channels and assigned 100 to the numbers. So now the 4K version of channel 2.1 is now 102.1. That means that I can now select what I want to watch the same broadcast and either HD or 4K. Of course, at this time nothing is being broadcast in 4k, however the 4K channel is converted to HEVC which gives a much lower bit rate"I interpreted it that he watched in 4k when I read ''I watched a couple of the NFL games tonight that were broadcast in "4k" .
ATSC 3.0 and HEVC is no indication of what resolution is being sent/watched.
I think that information's all upthread starting about here. RF 31 is the host and the format's are all the same: WDIV is 1080i, WXYZ is 720p, etc.I am curious about how the Detroit stations broadcasting in ATSC 3.0 are being hosted. Are they all sharing a single RF channel? And I am also curious about the resolution they are broadcasting in, i.e has anyone dug into the transport stream details to see what format (480p, 720p etc).
Thanks, exactly what I was looking for. I imagine the stations are or will be touting their new "crystal clear UHD" format signals, all while they are packed into the same RF channel, at the same or worse resolution than they use for ATSC 1.0, lol. But at the very least, the ATSC 3.0 format will provide for many more of the (lower) resolution subchannels to be packed into each RF slot, once there is a complete changeover, even if broadcasting in 4k is not used much.I think that information's all upthread starting about here. RF 31 is the host and the format's are all the same: WDIV is 1080i, WXYZ is 720p, etc.
I think - also upthread - there's a reference to WMYD doing some HDR programming, but nobody's doing anything more than that as the programming they carry isn't distributed as such and - to my knowledge - none of the stations is investing in the necessary equipment for a whole new, separate air chain. Until the networks and syndicators show any interest in distributing content in higher resolutions to stations, there's no point in making the investment.Thanks, exactly what I was looking for. I imagine the stations are or will be touting their new "crystal clear UHD" format signals, all while they are packed into the same RF channel, at the same or worse resolution than they use for ATSC 1.0, lol. But at the very least, the ATSC 3.0 format will provide for many more of the (lower) resolution subchannels to be packed into each RF slot, once there is a complete changeover, even if broadcasting in 4k is not used much.
I haven’t seen any promotion of it so far on the ATSC 1.0 channels. I think they are mainly testing ATSC 3.0 right now.Thanks, exactly what I was looking for. I imagine the stations are or will be touting their new "crystal clear UHD" format signals, all while they are packed into the same RF channel, at the same or worse resolution than they use for ATSC 1.0, lol. But at the very least, the ATSC 3.0 format will provide for many more of the (lower) resolution subchannels to be packed into each RF slot, once there is a complete changeover, even if broadcasting in 4k is not used much.
It'd be counterproductive to promote something the audience cannot access.I haven’t seen any promotion of it so far on the ATSC 1.0 channels. I think they are mainly testing ATSC 3.0 right now.
WXYZ has been running NextGenTV promos.It'd be counterproductive to promote something the audience cannot access.
