As I understand it, the HDMI standard allows for output to be a digitized version of either RGB or YCbCr. I also believe that DVDs are encoded as YCbCr. Thus, there is no color space conversion if you output YCbCr over HDMI.
On the other hand, DVI is only an RGB interface. Thus, if you want to send an HDMI signal through a conversion plug to a DVI device, you have to convert from YCbCr to RGB first.
Ira
Ira
