Status
Not open for further replies.
1 - 15 of 15 Posts
I would love to kow as well.
I bought the Mi1Da adapter from digital connections, and can't put my wire cover over top of the end connector of the DVI and the adapter.
Does anyone know where I can get 15-20 foot DVI male to M1 Da male???
Cheers,
Requis
Are you referring to the DVI/P&D adaptor? I am building my theater and would prefer to run a straight DVI cable in the wall so I am not limited by manufacturer later if I change projectors. I plan to install a 7200 as soon as the next round of rebates come out:D
Just make sure you buy a "D" capable cable. There are some P&D - DVI-A cables out there and those won't work on the IF7200.
I just lost a lot of time trying to plug-in my HTPC to my IF7200 with one of those cables. :(
Anybody having any luck finding a P&D - DVI-D 5m (15 feet) cable?
Since that's the physical limit, I can't believe nobody's making them...
-eric
Hi All,
Frankly I'm a very confused by the various flavors of DVI, but especially with regard to mating DVI cables with the InFocus P&D (AKA M1 DA) input. Furthermore I don't have the foggiest idea of what the difference is between single link and dual link DVI cables.
I plan on purchasing an InFocus ScreenPlay 7200 and in preparation I prewired my home theater with various video cables including DVI. I had always received good service and quality from BetterCables, so I ordered from them. They had a 9 meter Dual Link DVI-D cable.
I knew that the InFocus projector used a different input connector and I figured I would need some sort of adapter. I saw the Digital Connections' DVI-D Receptacle to P&D Digital Plug Adapter , and figured that I would probably order one of those when the time came to install the projector.
Anyway, tonight just out of curiousity I started checking out various web sites selling DVI adapters to see if I could get some background on the DVI subject. I found a company called DVIGear. They were selling an adapter which appeared to be the same as Digital Connection's. Here's a link to it:
DVI-D Female to P&D / M1 Male. I was dismayed to read their remark:
This adapter will ONLY work with single link connections. Dual link is not supported.
So, to get to my question, is anyone using Dual Link DVI-D cable to connect to an InFocus ScreenPlay 7200? Can anyone explain to me the difference in single versus dual link cables as it relates to the InFocus projector? Am I going to have to replace the Dual Link?
Thanks in advance.
Larry
Larry,
I use the adapter with Dual Link cables as we don't sell any single link.
Hi Kei,
Thanks very much!!
I guess I can stop worrying now, and just order the "InFocus Do-Hickey" as you call it. ;)
Before I discovered this thread I sent an email to your "Questions?" email address. I see that someone at Digital Connections just read my message, perhaps it was you. If so, please don't bother responding again.
Thanks again.
Larry
Larry,
I don't know why but my e-mail stopped coming in at about 4:30PM today, then all of a sudden all the missing e-mails showed up about an hour ago. I guess we had a server problem. I saw your post and e-mail at about the same time. I'm staring to hate e-mail. Even with filters, 80% of all incoming e-mails are spam.
Hi Kei,
Yeah, ain't technology great! But, I guess we shouldn't knock it, without it we'd be watching "home theater" on 13" black & white TV's, and you'd be in a different business. :D
By the way, I got a response from DVIGear. They said that their adapter wouldn't handle two video channels for high bandwidth/resolution applications, but it will work fine with dual link cables.
Thanks again.
Larry
Originally posted by glenned
You can get a 4" pigtail DVI to M1DA adapter for $23 at www.lindy.com that will allow you to use the Infocus Cable Cover. This allows you to use a standard DVI-D cable to supply the PJ.
I have this connector and no longer needed. PM me if interested!
1 - 15 of 15 Posts
Status
