1 - 7 of 7 Posts
Hello
I´m about to buy a new 60" plasma.
I have a 60pa6500 here but I´m not that happy with the SD/HD picture though I tried everything with the settings. So my thougth was to buy a pm6700 instead but I cant find an answer (googling for 2 days) if it has the same picture (same plasma panel inside?) or if the pm6700 has a better picture?
So...Has the pm6700 a better black level / contrast than the pa6500? Is the picture overall better on the pm6700 compared to the pa6500?
(i know the pm6700 is a smart / 3D tv, but thats only a plus... My concern is the picture compared to the pa6500)
thx
Discussion Starter · #5 ·
I can se mine is a pa5500 an not a pa6500.. But they should be the same...
I have read that thread.. But there is no answer about the pm6700 (pm670t) vs the pa6500.
I was hoping someone inhere could tell me if they have the same picture...
The pm6700 is THX certified though.. the pa6500 is not....
Discussion Starter · #7 ·
no... (and yes)
I want to know if the quality of the picture on the pa6500 is identical with the quality on the picture on the pm6700..or if the picture on the pm6700 is better!
The pm6700 is THX certified, so it can only be better or?
I dont want to pay more for the pm6700 if it has the same picture as the pa6500... I dont need 3D and smart function
Could be nice to know if it is the same panel inside eventhough is not an answer to if the pictures are identical. The picture can still be better on the pm6700 because of another calibration, engine and so...
Has anypne compared the pa6500 and pm6700 and know about my question?
1 - 7 of 7 Posts
