1 - 1 of 1 Posts
Hello, I've finally arrived at the tv buying stage where only 2 tv's are still in the running: the Samsung F6300 (120 hz native, 240 CMR, edge lit) and the LG LN5700 (60 hz native, 120 hz Tru-Motion, back lit).
I will be using the TV mainly for gaming, where a tiny bit of lag is acceptable if it reduces motion blur by a lot.
Which one of these two would you recommend, and why?
Edit: or would possibly the EH6030 be a good option as well, it seems to be a F6300 without the Smart part, but a lot cheaper?
1 - 1 of 1 Posts
