1 - 4 of 4 Posts
Is there a noticeable difference in sound quality between the old Klipsch RF series speakers and the new Klipsch RF series II speakers? I can purchase the older Klipsch RF-82 speakers for $436.00 less than the newer RF-82 II speakers. Are the new Klipsch RF series speakers worth the extra money?
Roger
Roger
RF-82
FREQUENCY RESPONSE 33Hz-23kHz +/-3dB
POWER HANDLING 150W RMS / 600W Peak
SENSITIVITY 98dB @ 2.83V / 1m
NOMINAL IMPEDANCE 8 ohms compatible
HIGH FREQ CROSSOVER 2000Hz
HIGH FREQUENCY DRIVERS 1" (2.54cm) Titanium diaphragm compression driver mated to 90x60 square Tractrix® Horn
LOW FREQUENCY DRIVERS Dual 8" (20.3cm) Cerametallic cone woofers
ENCLOSURE TYPE Bass-reflex via dual rear-firing ports
HEIGHT 43.6" (110.7cm) (w/feet)
WIDTH 9.5" (24.1cm)
DEPTH 16.25" (41.3cm)
WEIGHT 66lbs (30kg)
FINISHES Black Ash woodgrain vinyl
BUILT FROM 2006
BUILT UNTIL 2010
RF-82II
FREQUENCY RESPONSE 33Hz-24KHz ± 3dB
HIGH FREQ CROSSOVER 1400Hz
HIGH FREQUENCY DRIVERS 1" (2.54cm) Titanium diaphragm compression driver mated to 90° x 60° square Tractrix® Horn
INPUTS Dual binding posts / bi-wire / bi-amp
HEIGHT 43.9" (111.4cm) with feet
WIDTH 9.3" (23.5cm)
DEPTH 16.3" (41.4cm) with grille
WEIGHT 61.5lbs (32.2kg)
FINISHES Black Ash & Cherry woodgrain vinyl
BUILT FROM 2010
The other difference not listed are the foot pegs on them are different in the newer versions
all info taken from Klipsch.com
bi-amp? all you need is some 10-20W to drive these speakers :)
Don't waste your money bi-amping or bi-wiring any speaker.
They took some 5 lbs out. Wonder where it came from? Poor bracing? They always claim to have introduced new technology and state-of-the-art cross overs that magically improved performance and reduced weight. Wonder how the cost of RB-75 reduced when it transformed to RB-81? No real wood, plastic binding posts, flimsy jumpers, thin box, cheapo styrofoam that always breaks. I didn't mind as the tweeters were a lot smoother and sharper compared to RB-35 (smaller than RB-75). A lot of people still think RB-75 and RF-7 are superior.
Same with AVR's. The weight keeps dropping and the power also keeps dropping. They have to cut corners somewhere to reduce the already dirt cheap manufacturing cost in China! They just say they added new technology. I don't buy any of those marketing BS. Buy the older models when supplies last. They had $200 off RF-82's but they are all sold out.
1 - 4 of 4 Posts
