I'd love to use clips and hat channel, but I'm afraid thats not in my budget. I've seen the clips that isolate the studs from the top plate, but that is out of my range too. I thought of an idea, but I'm not sure if it would serve my purpose. I hope this makes sense! My idea is to nail in a 2x4 to the joists where the walls are going to be. Then build the stud wall like normal, just a tad shorter than it should be, leaving a space between the top plate and the other 2x4 attached to the joists. In the space between use rubber or urethane bushing to isolate the wall from the joists and run a bolt through. Maybe every 4 feet or so. Wouldn't this be a cheap way of decoupling the wall from the house? I do plan to DD & GG the walls.
Thanks in advance!
Thanks in advance!
