I am using a JBL DSC1000 receiver. I currently have my HTPC connected to it via coaxial digital audio. I have, however, had the same problem playing audio from all sources through the digital audio inputs.
When I am playing audio to the receiver via a digital audio connection, it plays fine for a while and I get excellent sound. After a while though, a slight crackling noise appears in the audio which, over the course of 10 - 20 seconds grows to be a lot worse. The audio then cuts out completely for a couple of seconds, and when it comes back the crackling is gone and the audio is back to normal. This happens regularly, say every 10 minutes for example. The time between instances is different depending on the piece of equipment I am using as a source.
Thats the best description I can give I'm afraid, but it is REALLY annoying and really makes my whole setup a pain in the ass to use. Have any of you experienced this phenomenon before? If so is there a way around it without any serious implications? Or do I just have a flawed receiver?
This is driving me crazy anyway, and I would really appreciate any input any of you might have on this problem.
