Status
Not open for further replies.
1 - 5 of 5 Posts
Well, here's my story in a nutshell. My receiver only has Optical Digital inputs. Right now I have a SB Live with a hoontech adapter to give me the Optical Digital output. The SB Live! is creating havoc on my system, and I need to get rid of it. My motherboard Asus P4S533 has SPDIF output. I need to find a converter of some type for it so I can take the signal from the motherboard audio output to the receiver.
Can anyone help me locate someplace I can get something like that?
Sean
I've used a Midiman CO2 but you might want to look into the Audio Authority 1177 since it also switches 4 different inputs to one output and it may come in handy some day. Digital Connection sells the Audio Authority 1177.
Mark
Dizzy49 - The smarthome is a good price but if you go to radio-shack you can get one for a little more that lets you select your input type and it will deliver the other format on the output via a little switch. This would allow a little more options when you use it. Not sure about shipping .vs. sales tax .vs. immediate gratification.
1 - 5 of 5 Posts
Status
