Status
Not open for further replies.
1 - 2 of 2 Posts
I've searched the forums and haven't seen digital cable mentioned much in relation to modulation. I would like to use the ChannelPlus 5645 to modulate my security camera, dvd, replay, and hopefully digital cable. The analog band has some empty channels in the 80s, so I think I have room. Anyone with any experience with this?
Brett
I have modulated digital cable, it is no different than modulating any other AV source. Make sure that you use a channel block filter such as Channel Plus LPF-600 to keep out any cable channel interference. Even if they have no programing on those channels, it doesn't mean that they are not pumping a signal at those frequencies.:D
1 - 2 of 2 Posts
Status
