I need to run a digital coaxial cable from my Comcast HD Cable box to my receiver to get the Dolby Digital sound. I have a good quality Monster Cable video cable. Would that work fine as a coaxial digital cable and give me my 5.1 digital sound?
LIVE: AVSForum Tech Talk Podcast with Scott Wilkinson, Episode 5 Click here for details.
Enter to be our Home Theater of the Month Click here for details.
Originally Posted by ChrisWiggles /forum/post/0
Yes.
A video cable is a 75ohm coax. A digital audio coax is a 75ohm coax. Being that both are 75ohm coax, they are identical thus they are interchangeable.
Analog audio cables may not be 75ohm coax. You can use a 75ohm cable just fine for audio, but the inverse is not true unless the cable is indeed 75ohm (or you may run into degradations with video or dropouts with digital audio.)
hope that helps!
Oh and you can get better cheaper cables than monster usually...
