THD measurements are as sick as power ratings these days, IMHO.
Class AB designs always distort more in higher frequencies than lower, due to feedback. That's why most THD measurements are taken at 1khz at 1 watt. Feedback can even be tweaked to have super low THD measurements at 1khz. Good class-d designs (all "digital" amps should be based on some sort of class-d) are linear in feedback, distortion is linear across the bandwidth - that's why they also measure higher in distortion. Good class-d designs have nice thd levels as well actually, for example Hypex UcD's measure in the 0.0x range, over the entire bandwidth.
Next thing is, you have analog amps, analog class-d amps and pure digital amps - the difference (simplified)? Class-d needs a PWM signal to operate. The analog class-d versions take analog sound in, convert it with A/D to PWM and amplify. full digital designs take the PCM signal, convert it into digital domain to PWM and amplify - no digital to analog conversion before the amplification.
The middle solution can also be very good, because D/A's are already very advanced these days, purely digital should be best on paper, but of course, how well the switching works, and the quality of the power supply, is the defining quality factor in digital amps. Digital not = perfect
I've settled on building my own analog class-d amps based on Hypex UcD's. I have 2 channels already, and it's wonderful compared to same-priced (and even much more expensive) analog class-ab amps.
