1 - 3 of 3 Posts
Is there a sound difference between
Connecting an toslink cable
  • directly from a Xbox to a receiver
  • from a HDMI switcher which gets the signal from the Xbox trough HDMI 2.0... to the receiver
Try both and determine if you hear a difference. Use the one that works best for you.
Probably no audible difference though.
It's no different than using digital coax cable A and digital coax cable B.
1 - 3 of 3 Posts
