1 - 20 of 29 Posts
Premium Member
When it comes to high-end digital projectors, Digital Projection International (DPI) is hard to beat. At CEDIA this year, the company introduced two new alternative-illumination models—the Insight 4K Laser and Insight 4K LED. Both are 3-chip DLP designs using true 4K DMD imagers (4096x2160) and as their names imply, they use lasers and LEDs, respectively, as the light source.
The Insight 4K Laser is similar in concept to the other laser projectors at the show. The light from an array of blue-laser diodes is split—part of it is used to excite yellow phosphor on a spinning wheel, producing yellow light that is then split into red and green, which illuminate the corresponding imagers. The rest of the blue laser light illuminates the blue imager. The light engine is rated at 20,000 hours to half brightness, and unlike the other laser projectors at CEDIA, it can be replaced.
Also unlike the other laser projectors at the show, this one can output up to 12,000 lumens, which means it can fill a screen up to 36 feet wide in a light-controlled room. It also features 12-bit color, but the gamut barely reaches beyond BT.709. Its two HDMI inputs support HDCP 2.2.
As seen in the photo above, the Insight 4K laser was demonstrated out on the show floor on an 8-foot-diagonal dnp Supernova ambient light-rejecting screen using unfamiliar 4K footage. With 12-bit color, the gradations in the colors of the sunset behind the Eiffel Tower in this shot were super-smooth and devoid of any banding.
The Insight 4K LED, which uses an identical housing as the 4K Laser, was demonstrated in a darkened room on a 12-foot-wide, 16:9 Stewart StudioTek 130 screen, most likely because its peak light output is 2000-3000 lumens. It uses red, green, and blue LEDs to directly illuminate the DMD imagers, and the LED engine can be replaced after its 60,000-hour lifespan has elapsed. Most remarkably, it achieves a color gamut very close to BT.2020; in fact, it's the first display I know of to do so, and DPI claims it's the only projector that can reproduce that gamut and true 4K resolution.
Before the demo footage was shown, a representative went through a PowerPoint presentation, and one of the points he made was that more-saturated colors appear brighter than less-saturated versions of the same colors, even though they measure the same brightness. This is called the Helmholtz-Kohlrausch (HK) effect, and it could well be why most viewers are attracted to more-saturated colors.
The demo footage included the same native 4K content being shown by the Insight 4K Laser on the show floor as well as the trailer for Elysium and clips from Tears of Steel, a very cool live-action/CGI sci-fi short. Unfortunately, the content had not been graded for the projector's wide color gamut, and it looked quite oversaturated to me—though I also recognized the HK effect in my visceral response (ooh, look at the pretty eye candy!). On the plus side, the Insight 4K LED implements 12-bit color, and as with the 4K Laser, subtle gradations were silky smooth with nary a hint of banding.
Despite the oversaturation on the material used in the demo, I'm very excited about both of these projectors, especially the Insight 4K LED. If 4K content is released with the BT.2020 color gamut, this is the only display device I know of that will be able to reproduce it accurately, at least for now. Of course that capability doesn't come cheap—the Insight 4K LED will set you back $150,000! (The 4K Laser is actually less—only $120,000.) But DPI is clearly pointing the way toward the future of display technology, and I'm glad to be along for the ride.
Return to Master CEDIA 2014 Thread
Like AVS Forum on Facebook
Follow AVS Forum on Twitter
+1 AVS Forum on Google+
I'm not aware of a bt 2020 source from Tears of steel.
This is a lossless copy of the short film "Tears of Steel". This directory contains a set of 4096x1714 16-bit sRGB tiff files at 24 frames per second from the regraded 4k render of the film premiered May 26, 2013 at the Seattle International Film festival and released on YouTube 2013 June 2.
sRGB so bt 789 gamut with a different gamma.
but a device with nearly bt 2020 just wow and this with LED and nothing new like laser.
Premium Member
Discussion Starter · #3 ·
^^^ Where did you get the info about Tears of Steel? None of this was mentioned at the demo. Yes, I was very impressed that an LED projector could do BT.2020.
It must use a whole mess of red and green LEDs at close to the 2020 primaries and some neat lenses to focus all those LEDs so that it can hit the relevant modulating chip.
JVC RS500U, 2.35:1 125" screen, Marantz AV7705, 11.2 Def Tech speakers, Sunfire Theater Grand 400x7
Tears of Steel 4K can be downloaded here in .mov (or DCP for those of you that own a movie theater). According to this site "the 4k .mov file is h.264 encoded with Blender, rename to .mp4 and it works fine."
I watched this on my Sony VPL-VW1100ES and it looks very good.
Banned
Lol whomever you quoted that from doesn't know how files work. Just because you rename the extension doesn't mean you change the file container type. :rolleyes:
sorry forgot the link:
https://media.xiph.org/mango/tearsofsteel-4k-tiff/
xiph.org host a lot of lossless version from open movies like tears of steel.
the normal version on there page are Kbit starved at least in my eyes.
the raw shoots of the camera can be found here (should be totally lossless)
These are VFX plates from the mango open movie. They are 4k raw files in the native format of the Sony F65 digital cinema camera.
https://media.xiph.org/mango/raw/ these raw data can be easily in a colorspace higher than sRGB/BT 709
and I don't know if they hosted a BT 2020 version of the CGI anywhere.
True but I think H.264 .mov files are really an mp4 container, just with a different extension, so in this case the renaming is just for file associations/recognition.
One thing I'm curious about is, are these still using the DCI chips or are these machines using the HT chips that are supposed to be available in 2015?
I bought my projector in March and still don't have my HT done. I was starting to think I should have waited to buy as fear of a tech jump is omnipresent....until I saw the price tag. Yikes. Condo at the beach...4K laser projector...condo at the beach...4K laser projector...
I have wondered, more than once, if the DPI Insight 4K LED projector, is, or was the 4K LED projector that NEC Pro hyped, then mysteriously it disappeared., and DPI's unit popped up. Coincidence? I think not.
They use the same DCI type of 4K DMDs as used in projectors for commercial cinemas.
Banned
Where did read about new DMDs coming out in 2015? The only thing I've heard is that the DCI agreement with TI ends in 2015, but as far as I'm aware there hasn't been anything official or even rumored at by a reliable source about a new, smaller, 4K DMD coming to market.
I thought Ron posted something a while ago about consumer 4K DMDs coming. As for my question, I guess I worded it poorly, instead of "supposed to", I should have said "able to".
Last year at Infocom two reps from a manufacturer of consumer/business/education class of projectors (i.e., not ultra high end HT or digital cinema) told me that the unofficial info they had from TI indicated that there would the consumer class 4K DMD chips available in 2015.
Well TI and DCI are already in the works for a replacement for 4K DMD's. The natural choice would be 6,8 or 12K DMD's. Who knows with TI, there rather good at keeping secrets. Yes TI is free to market 4K DMD's to who ever wants them, around june or july of 2015, if i remember correctly.
Banned
That's not the problem though. Currently, TIs 4K DMD is 1.38" in size. This is FAR too large for home theater projector use. They have been completely mum when it comes to a smaller sized 4K DMD and that's what I'm referring to. Right now resolution is not the problem, it's the size of the DMD. If you don't understand why I'll be glad to explain.
I don't think the DMD is too big for home use, i think the CE's want you to except the cheap small junk there making as "perfect" HT projectors. If they were "perfect" for HT use, they wouldn't use a "cheap" plastic lens. The same TI chip in use in todays 720I/P/1080I/P/4K-UHD projectors, is the same DMD that fired RCA/Sony/JVC, etc projection tv's since 1994. No TI is not crazy, the CE's are.
Banned
None of this is true. TI has made several innovations since those early DMDs that make their performance much higher. Things like smaller fill factor between mirrors, darker substrates behind the mirrors, farther mirror tilt, higher/faster response times from the mirrors, more reflective coatings on the mirrors, and the list goes on. Yes the technology base is still there but the performance from it in no way resembles the DMDs from the mid-nineties.
On to the 1.38" true 4K DMD. Unless you have $10,000+ to spend or are perfectly fine with no zoom or lens shift capabilities, then sure, we might see them use these DMDs in consumer grade projectors. The optics needed to zoom upon and also shift upon them would need to be vastly larger than what we see in home theater projectors today. Larger optics cost a lot of money and that is the issue with this size DMD. If you take a look at what size the micro-displays in home theater projectors are you'll notice a trend. They're all (with the exception of the .95" DMD) around .6-.7" in size. This wasn't a mistake. They're that size because these companies know this is the appropriate size to use if you want to be able to use economically feasible lenses that can facilitate a decent amount of lens shift and zoom. You basically don't get that at all with .95" DMD projectors. For instance there isn't a single .95" DMD projector out there that has enough zoom to use the zoom method for constant image height applications until you reach the $15000+ process range. And the amount of zoom needed isn't a lot. 1.33x is that's needed. The aforementioned statement is the reason why. This, and the fact that the DMD is 4096 instead of 3840 horizontal mirrors, is the reason why I just can't see anyone but Sim2, Digital Projection, and Runco using this DMD and if they did I wouldn't call them "home theater" projectors because in all likelihood they'd be rebadged commercial cinema projectors anyways.
1 - 20 of 29 Posts
