Status
Not open for further replies.
1 - 1 of 1 Posts
I posted this over in the CRT section in response to a query in another thread, so some may have already seen this, but it's more pertinent here...
I keep reading that digital projectors have constant light output regardless of how much of the surface area is lit, but that's not what I'm finding when I measure them.
I have measured a difference in light output on a Sharp 9000 DLP between a 100 IRE window and 100 IRE full field, where the full field signal produces LESS output. Today I did the same measurements on a JVC G15 (Dukane) that I am calibrating, and thought the results might be of interest...
Projector: Freshly calibrated JVC G15 (Dukane) with 3 hours on the lamp.
Screen: Stewart 1.3 gain microperf 80" wide
Signal: [email protected] (HTPC) 4x3 image
100 IRE Window pattern = 30.9 ft lamberts
100 IRE Full screen = 29.2 ft lamberts
This is roughly 850 ANSI Lumens by the formula:
foot lamberts = (ANSI lumens) * (Screen Gain) / (screen area in square feet)
Signal: 720p 16x9 image (Accupel HDG-2000)
100 IRE Window pattern = 34 fl
100 IRE Full screen = 32 fl
So again, I am measuring lower light output with a full field white input signal than I am with a window pattern. And lower output with a 4x3 image than a 16x9 image.
I've no idea what causes this.
For these measurements: McMahan Lightspex in "*LUM" mode, fiber optic probe on tripod at 1 foot from screen surface, projector positioned to produce 80" wide image.
William
1 - 1 of 1 Posts
Status
