Originally Posted by rdgrimes /forum/post/20876734
You might want to re-think your entire setup and strategy, it may be needlessly complicated.
Are your analog sources really of such high quality that any of this is really a concern? Is your amp-speaker setup capable of resolving such tiny differences?
If so, consider a pure analog setup for 2-ch audio, separate from the video setup. That presumes the audio is analog to begin with (LPs or tape).
There are quite a few AVRs with video processing that equals the Edge, and audio processing to match. Ultimately you might find that a single high quality AVR will meet all these needs and you can do away with all the separate components.
Honestly, my speakers are very el cheapo. But, I'm always thinking ahead to the day I can buy better one's. The sources I have now are more than likely not so high quality (it are game consoles after all), but my gf is a lot more into music than I am, so I try to satisfy both possible uses.
I may eventually go with an amp + pre amp (Marantz 7005-series looks like an excellent choice). So buying an AVR solution may not be what I want. I'm upgrading to an Iscan DUO now, leaving the Lumagen Radiance-mini where it is (I can't afford their better equiped VP at the moment). Moreover, a Duo has a CMS and many other useful controls often not present in an AVR.
Seperating audio from video is the path I prefer the most. So I was thinking here to start with 2 channel audio and upgrade my surround system later with a pre amp and an amp.
Hence, my "quest" to find a device that can convert 2 channel analog to digital with great care. It would also be great if that device can (eventually)drive quality stereo speakers too, but for now it will drive my current speakers.
So, perhaps I'm looking for a HIFI amp+preamp (likely too expensive) or a all in 1 device for HIFI that I also happen to use for my analog audio from game consoles and what else I may own in the future.
I hope my above ranting makes sense. My video knowledge is pretty good but when it comes to audio I'm still trying to find my way.
