Maybe the lamp is defective, or the lamp powersupply. The lamp powersupply exists of 2 parts, the power supply and the ignition unit.
As the manual stated, first replace the lamp. If that doesn't help possible the powersupply is defective.
I have recently bought a defective G1000 of ebay with the same error. From standby to emergency in 15 seconds.
In my case there was absolutely no light coming from the lamp. After i repaired the defective ignition unit the lamp flashed and after i repaired the variable resistor regulating the power to the lamp, the projector was working
(the previous owner had completely destroyed this resistor using a hammer and chisel)
btw you can use dilard to ask the projector what the failure is.
regards,
Roberto
regards,
Roberto
