Hello
I have a problem with my DILA and would like some ideas as how to proceed.
I've searched the forum for simliar descriptions and found that Mark Rejhon had a similar problem with a cyan bar at the right edge of the image.
My problem is this:
After some minutes of operation (usually around 10) my DILA G10 suddenly displays the right third of the screen in purple. I take it, that this means that the green pixels aren't working.
After a short while (seconds) the whole picture startes flashing in a way that the HTPC feed "jumps" wildly on the screen. An interesting thing is, thatr the DILA menu, doesn't jump around as the HTPC feed.
Usually, after about 1 minute the picture then turns "inverted" or negative. This lasts about half a minute and suddenly the picture gets normal again.
I have a home-made hushbox with lots of ventilation, but when the problems began about half a year ago I thought it was because of overheating inside the box. For a long while I was right, because the problems went away as long as I removed the box. But now my DILA does it all the time.
I've connected the DILA to a GeForce 2 MX card in a HTPC. I'm using Power Strip and PowerDVD. The DILA has run about 600 hours on the first bulb.
What do I do now?
Jakob Jensen, Denmark.
My problem is this:
What do I do now?
