Status
Not open for further replies.
1 - 2 of 2 Posts
I will be installing Directv next week, already fired my cable co. Once everything is up I plan on installing a 4 x 8 switch so I can get my over the air & the 2 satellites out to 4 tvs, 2 Phillips DSR6ks, 1 basic receiver, and 1 HDTV receiver that will also be connected to an OTA hd antenna. My question is do I need to put diplexers on both of the lines going into the TIVOs to pull off the OTA signals and terminate one signal or can I get away with only 1 diplexer on 1 line feeding the OTA to the tv. Thanks.:confused:
You only need a diplexer when access to both the DBS and OTA feed is required. Each output of a 3xN or 5xN multiswitch may be..
- Directly connected to a satellite receiver
- Directly connected to a TV
- Connected to a satellite receiver and a TV using a diplexer
1 - 2 of 2 Posts
Status
