Status
Not open for further replies.
1 - 2 of 2 Posts
I have a new pj (300U) with DVI, component and composite connections. Should I run everything through my reveiver or connect each directly? I only have a VCR and DVD so I could do it and switch input at the pj. Has anyone tested for significant degrade when going through their receiver? TIA.
If you only have a dvd player and vcr it seems you should just bypass the reciever and go directly to the projector. The only point in using the receiver is if you need to use it as a switch. Depending on your receiver you may or may not notice a difference but why bother with the extra cables and the chance it degrades the picture if you don't need to?
1 - 2 of 2 Posts
Status
