Status
Not open for further replies.
1 - 2 of 2 Posts
I will be installing a dish this weekend on my apartment balcony for Direct TV HD-HBO. I already have the DCT-100 working fine for OTA HD.
Looks like I have a very clear line of sight based on where my neighbors are pointing. I'm about 30feet above the ground. Other than reading the instructions and adjusting the dish are there any tweaks/problems that I should be aware of?
Chris
LG 55" C9 OLED, Yamaha RX-A660, Monoprice 5.1.2 Speakers, WMC HTPC, TiVo Bolt, X1
Make sure the mast is completely plumb.
You can do a search for 8900, oval, elliptical, and you'll find a wealth of info.
"better living thru modern expensive electronics"
tm
1 - 2 of 2 Posts
Status
