Antennaweb is showing all-needed stations as yellow (~27 miles)--I think their a tad optimistic, mainly because of hills and trees, but close. (Molalla, Oregon [in town]).
All needed/wanted channels are from 326 to 328 degrees, so am looking for a directional, aesthetically reasonable antenna (FM 343 to 347 degrees). My research thus far has pointed me to the:
Channel Master CM-2018 (optimized for channels 7-51) -- is this overkill? I want as small as possible.
Do you think that this is a good fit? If it doesn't support FM, I'll probably get a dedicated FM antenna.
Finally, can I mount this type of antenna to an existing Dish-Network base (I sure hope so)?
