I just recieved my 3rd HDTV STB for D*for my new home theater The issue I have is that I only have 2 lines coming into my hoiuse from my triple LNB dish. Running a third line is not an option because they all run underground through a condiut. I would like to have all 3 STB's active because they are in different rooms.
What are my options?
I do have my house wired with multiple RG6 lines into a central hub so the STB's could be diay chained together if that is possible.
My only other option is to maybe get an RG6 switcher or manually disconnect and reconnect the lines from one feed to another STB when I need to. There would never be an instance when I would need to watch more than 1 STB at a time. My concern with not having a live feed into each STB all the time is that my card might keep going down if it is not hooked up to a dish 7 X24. Doesn't D* always send messages to each STB?
My last course of action would be to deactivate my STB in my bedroom and just use the other 2.
Any suggestions would be appreciated.
I was going to call D* to activate my new Sony STB but wanted to know my options first.
