Status
Not open for further replies.
1 - 1 of 1 Posts
I had an installer here for 5 hours. He couldn't get the oval dish to get a signal on the 119 sat. He kept pointing the dish at 240 degrees and saying tree was in the way. he was getting a 96 strength on the 101. Using the setup menu I see it should be pointed at 250 degrees. Of course at 250 degrees there was a clear line of sight to the sky. What he did was use an old round dish i have laying around and point that to the 119.
The problem is 119 shows 96 also, but I think he is pulling in the 101 or the 110 sat and not the 119. My HD stations show blank screen or not available in our area. Can't seem to get the HD channels.
I have hooked up a round dish in the past. My question is, should I try to adjust it and rehook it up myself giving it another try with the oval dish, using the coordinates on system, or should i try to run the oval dish and just use that to get the 119.
If so, what would be the coordinates for the 119 in Meriden, CT 06450?
Thanks for any help.
1 - 1 of 1 Posts
Status
