1 - 10 of 10 Posts
· Registered
I have an extra DirecTV HR-10 receiver that I would like to use in my home office and watch TV on a DELL 2007FP monitor. The monitor has standard VGA and DVI inputs. Not terribly concerned about HD right now even though the DirecTV receiver is a high def one. I just want the ability to watch TV while I'm working or relaxing in my home office.
What do I need to make this happen? Can I connect directly to my DELL monitor? Do I need to go through a computer's graphic card? ... Any suggestions would be greatly appreciated before I go out and buy a small LCD TV for the home office.
Thanks in advance.
· Registered
Try it out and see. You should be able to connect directly to the monitor. The DVR should have come with a HDMI > DVI cable, so you should be good to go. Then run your optical audio or composite audio cables to your PC or sound system.
BTW, you should have composite and s-video inputs on that monitor too if needed, but DVI should be the best way.
· Registered
Discussion Starter · #4 ·
So, short of buying a new LCD TV, there must be something on the market that can make this work.
It is not a matter of saving money, but rather a matter of saving desk space. Don't want 2 units on my desk..
· Registered
Did you try it out and it wouldn't work? Like I said, you can use composite or s-video if needed.
· Registered
Originally Posted by miniz /forum/post/0
What good is that going to do? Can't get an HD signal on S-video, sorry!
It would allow them to watch tv. That's what good it would do. No one said s-vid would carry HD - and it looks like that would be an acceptable solution:
I would still try out the HDMI > DVI cable just to make sure it won't work. Won't take but a minute to try.
· Registered
Discussion Starter · #9 ·
Turns out my DELL 2007FP has a Composite Video and S-Video input. Connected S-Video straight to my DirecTV receiver and it worked beautifully. Not top notch quality but it's serving its purpose. I had an old SD DirecTV receiver that I'm using so not to sacrifice a full HD receiver.
Just out of curiosity I'm going to hook up an HR-20 to the 2007FP through an HDMI>DVI cable and report back this weekend. Just need to find the HDMI>DVI cable. I know it came with the receiver.
· Registered
Excellent. Let us know if the HDMI>DVI cable works or not.
1 - 10 of 10 Posts
