Status
Not open for further replies.
1 - 2 of 2 Posts
Premium Member
I currently have 4 coax lines going from the 3 lnb dish to the head end. Two are being used for a HD TiVo and one is used for a SD TiVo, leaving 1 coax being unused. I want to try DirectWay.
1. Will the DirectWay dish replace the 3 lnb dish?
2. How many additional coax lines do I need for a DirectWay connection?
3. When MPEG4 comes to my area, will all these connections & dishes change?
4. What the best way to add DirectWay based on my current setup?
Thanx -
1. No, they don't make a combo 3 LNB Directway dish, you'll have two seperate ones.
2. I believe it's two, one for receiving, one for transmitting.
3. They will be mounted independant of one another so only your exisiting 3 LNB dish would be impacted.
4. The dish and cable runs would be seperate from your existing install.
1 - 2 of 2 Posts
Status
