Status
Not open for further replies.
1 - 5 of 5 Posts
Use Mozilla, or go to "Control Panel > Sounds and Multimedia" and change "Start Navigation" to "none" or whatever sound you would like to hear.
Discussion Starter · #3 ·
Mozilla doesn't work with NT auth or MS websites very well. I don't see the setting your talking about in control panel.
You're probably using XP then; I can't help you.
in Win2k its control panel, sounds, sounds tab, under Windows Explorer uncheck "start navigation"
1 - 5 of 5 Posts
Status
