Status
Not open for further replies.
1 - 9 of 9 Posts
Try this for the output code. It works for me.
0000 0067 0000 0010 0060 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0303
The codes are for the Pronto remote. Diferent codes for different remote actions.
Bobco did that code I posted work for your Output?
[This message has been edited by Grizz (edited 04-16-2001).]
Yes you are correct. Its just the IR code to toggle through the outputs. Sorry. So you are looking for the discrete codes to select the different outputs on the HD100? Like Video 3 variable, Video 3 1080i, Video 3 480i. Or the different video inputs on your Tv? I have the Sony 61HS10 and if I set the HD100 to Video 3 variable I have the discrete codes for selecting the various Video outputs.1,2,3,4,5 on the TV, programmed into my Pronto.
If you have a Sony I think these codes will work for you. If I'm misunderstanding you I'm sorry
Discussion Starter · #7 ·
I do not own a Pronto. Can I use one of the Radioshack Learning remotes (that has a device code for an older Sony Satellite box) to program discreet On and Off codes into my Theater Master 9000 learning remote?
If not, would I be ble to get them into an RTI or new Theatermaster mX-500? Finally, is the only way to do this to find a used Pronto that I use just to get these codes into my other learning remote?
Originally posted by Hacky:
I do not own a Pronto. Can I use one of the Radioshack Learning remotes (that has a device code for an older Sony Satellite box) to program discreet On and Off codes into my Theater Master 9000 learning remote?"
"If not, would I be ble to get them into an RTI or new Theatermaster mX-500? Finally, is the only way to do this to find a used Pronto that I use just to get these codes into my other learning remote?
You cannot directly program these discreet codes into any remote other than the Pronto. Than you can learn these codes into other remotes, if the remote takes it.
1 - 9 of 9 Posts
Status
