Status
Not open for further replies.
1 - 3 of 3 Posts
i have the 811 hdtv receiver, and i only want HDTV programing, i know the dish 500 will pick up dishnetwork HD pak , 110
my question is to get the voom pak do i need another dish and which dish do i need , ?
i doing the install myself , and trying to get info on voom set up is not a easy, dishnetwork tech don't even know , are they just dont tell you what is needed
my equipment so far:
single tv set up
panasonic 50' plasma
811 hdtv receiver
Dish Network Dish 500 w/Pro Twin LNB DP Twin• FTA
thanks and sorry for the newb ? :p
1 - 3 of 3 Posts
Status
