Status
Not open for further replies.
1 - 3 of 3 Posts
Can you plug a computer monitor into the Dish 6000 RGB port with a HDTV 1080i feed?
If so, what signal is the monitor seeing, 720p or 480p?
Hmmmm. Let me know.
The Dish 6000 only does 720p and 1080i. I use 720p with my presentation monitor. Some computer monitors will also accept an interlaced 1080i signal, but mine won't. The Dish 6000 will up/down convert whatever you throw at it, depending on how you set up the outputs. For instance, 1080i will be downconverted to 720p if that's how you have the outputs setup.
Dennis
Dennis Whiteman
FastPipe Media, Inc.
1 - 3 of 3 Posts
Status
